Daewoo DWLED-48FHDS: no puedo salir de Aging mide
ricardoz56
Mensaje por ricardoz56 »
Buenas tengo un led Daewoo dwled-48fhds que no puedo salir del model aging agradecido cualquier ayuda
Re: Aging mide
Menu Fábrica:
Following TCL standard and practices, it’s required minimum 15min of Warm-Up that can be
considered as Burn-In.
Additional Aging for White Balance alignment is no more necessary due to consistent Picture
Performance with Cloning usage.
This function is accessible by selecting “Factory menu; WARM-UP”, pressing key board
“menu” key and then leaving Factory menu. Other faster methods are available on above
enclosed SIACP requirements (rev. v3.9).
fijate dentro del menu service si aparese modo aging o tofac
ricardoz56
Re: Aging mide
No se puede entrar a ningún menú solamente cambia de colores igual gracias
